dave_525
ParticipantRe: Servis M9503W washer-dryer dead
I see now how the interlock switch works – live incoming to pin 3 neutral on pin 1 and the switch operates (if the door is closed) and you get live out of pin 2. I’m not getting neutral continuity to pin 1 though – where does this neutral feed come from? Presumably a sensor that says if there is still water in the machine?
dave_525
Is the interlock switch a straightforward changeover switch or is it more complicated than that? Trying to check the new one and getting myself confused.
dave_525
That checks ok Muv. Must be something else.
dave_525
At the top rear where the cable comes through the back panel?
dave_525
ParticipantRe: AEG 6470 slimline stopped dead
Thanks Dave,
E-No: 911735005
F-No: 039379008While you have your spares catalogue open I could also use:
a set of wheels
a cutlery basket
a grey plastic nozzle that fits to the underside of the lower armta
dave_525
Took it apart last night. The on/off switch has failed. How much is a new one?
