helo_75 wrote:nah, its more likely to be blocked with fluff in the condenser, needs airflow to keep the elemst at a safe temperature.. the condenser is the plastic tube from the base of the fan unit to the drum…
be very careful, lots of sharp edges, and tightly fitted parts
safety first… it hurts!
oh, and plug out of course!!
Have checked and tested motor and capacitor. Have noticed that the blower which is directly on the back of the drum has its spindle stuck and will not rotate. But to get at and remove this i need to first remove the drum flywheel. I have tried using an allen key (is it conventional when removing allen bolt…anticlockwise??)
Thanks.
