Re: OCEAN FREEZER TECHNICAL HELP please
HI Bryan
Its very good of you to take the time to reply with advice thank you.
I had wondered about the time delay when pluged in but having read the instruction manual for a hotpoint freezer which explained this i feel a bit relieved
At the moment its working fine although when the door is left open it does not start up for some time is that because its empty except for two jugs of water (frozen) ? and looking through the grill at the top how much ice or frost if any is normal on the fins (its very hard to get the cover out as this supports the whole assembly) so its difficult to see if the defrost part is working , the drain vent tube makes a gurgling noise when the door is shut so that may be a good sign (the pipe was detached from the top on the back before ) it may be that i am worrying to much and its working fine the trouble is with these things is you dont take any notice of when they are working !! but i have to say i have learnt a lot already from this club/site.
any further reasurance or advice would be most welcome.
Regards Dave
