David_M
  • in reply to: Bosch WFF2001GB/01 – Drum not spinning #181949
    David_M
    Re: Bosch WFF2001GB/01 – Drum not spinning
    Update: Got the motor out OK and checked the brushes – both worn down to approx. 3/8ths of an inch (or 1cm). Have ordered replacement brushes from Shop@. Many thanks for your help.
    Cheers,
    David
    in reply to: Bosch WFF2001GB/01 – Drum not spinning #181948
    David_M
    No problem. Actually, was just going to edit my post to say I found some instructions online at http://www.howtomendit.com/answers.php?id=1800. Will see how well it goes, but if I get stuck or don’t think I can do it, I’ll take your advice.
    Thanks,
    David
    in reply to: Bosch WFF2001GB/01 – Drum not spinning #181946
    David_M
    Re: Bosch WFF2001/GB – Drum not spinning
    gegsy wrote:If you remove motor and check brushes, Im sure you will find them worn down (App 1.5″).
    I’ve got the back off the washing machine. Any suggestions where I can find instructions on how to remove the motor? Don’t want to damage it or anything trying to get it off. Sorry if that’s a silly question or anything.
