dnaxton
Viewing 3 posts - 31 through 33 (of 33 total)
  • in reply to: Help required with a hotpoint Electronic 800 De luxe 9526 #154103
    dnaxton
    Re: Advice/help required
    How tight are these drum pulleys screwed on as mine isn’t moving at all.
    Dave 🙁
    in reply to: Help required with a hotpoint Electronic 800 De luxe 9526 #154102
    dnaxton
    Martin wrote:Someone will need to hold the broken shaft on the inside of the drum whilst you unscrew the pulley (anticlockwise).
    (I’ve amended the link for the spare parts you need by the way in my previous post – above)
    Cheers for the LINK.
    So i have a broken drum spider……….. 🙁 😉
    Are the bearings easy to fit.
    Thanks for all your help.
    in reply to: Help required with a hotpoint Electronic 800 De luxe 9526 #154100
    dnaxton
    Martin wrote:Dave,
    It will need a new drum shaft and bearing kit (Part No 1611166) so the bearing will need taking out to do a proper job ( the drum pulley screws on by the way)
    Replacement part available via emailing detaiils to spares@ukwhitegoods.co.uk
    Hi Martin,
    How hard is it to remove the drum pulley as mine just keep turning the whole shaft.
    Any tips
    Regards
