The plastic rod that takes the knob snapped off. The selector itself worked fine but I couldn’t change functions.
I wired the new selector with the same wiring positions as the old one but I have since found out it is a different configuration on the newer switches – you need to skip the fourth terminal
so yes it was incorrect wiring that has caused something to trip, I just don’t know what has tripped
