Dr. No
  • in reply to: Beko DWD5411 diswasher leaking from the float switch #453247
    Dr. No
    Re: Beko DWD5411 diswasher leaking from the float switch
    Hi Dave,
    I checked everything today and found no blockage or leak from anywhere. But it still would not fill with water. I got fedup and chaged the inlet valve anyway. All seems to be working fine now. I am guessing when I tilted/rocked the machine water must have gone somewhere where it shouldn’t have and came out via the float switch. I tried to run cycle and so far so good. Fingers crossed it was the inlet valve only.
    Thank you for taking the time to reply, which was much appreciated.
    Mefty
    in reply to: Beko DWD5411 diswasher leaking from the float switch #453245
    Dr. No
    Hi Dave,
    Thanks very much for the reply.
    Little bit of water came out when I started the washer. It’s when the pump initially kicks in to drain whatever is left in the machine from prev run. So not much came out but enough to trip the float switch. It never flooded, which is why I didn’t notice it before (float switch doing its job by the looks of it).
    Could it be that the drain pipe or pump is partially bloked?
    Thanks.
    Mefty
