el_steveo
  • in reply to: Blomberg 1501AAA not spinning #113885
    el_steveo
    Re: Blomberg 1501AAA not spinning
    Update – called out an engineer….checked it all out – fault is in the electronics……time for a new machine….
    in reply to: Blomberg 1501AAA not spinning #113884
    el_steveo
    Hi Pengiun,
    Had a look at the carbons they are only about half way through – I took out the motor cleaned it up reinstalled it. Cleaned out the little port on the front of the machine (there was a bra wire in there) – anyways its still not working.
    What happens now is it starts to rotate then stops , waits a few mins goes to start a rotation then stops etc etc….pump seems to be ok , motor is turning , the drum rotates but seems to trip out after 1 sec..
    I also cleaned out the pressure bell , but didn’t notice anything suspect (very small amount of sludge).
    I suspect maybe elctronics prob now – any ideas ??
    Somebody mentioned an unbalance sensor – ?
    in reply to: Blomberg 1501AAA not spinning #113882
    el_steveo
    Hi – I Have a slightly different Spin issue with my Blomberg – its operator (the wife 😀 ) has a tendeceny to run it always at max RPM (1500)on spin…recently its started tripping a circuit breaker when its on its spin cycle……so I reduce the spin speed to 1300 and it doesn’t trip the breaker anymore but it does sound like its having a job maintaining the spin speed, therefore I suspect the belt is maybe slipping or worn out (its about 5yrs old)
    Anybody know which belt I should buy and where I can get it – most of the net sites dont seem to stock them….or if you have any other suggestions I’d appreciate it .
    Many thanks for looking.
