emz_77
  • in reply to: Bauknecht gsx7551 manual #328907
    emz_77
    Re: Bauknecht gsx7551 manual
    Hello again!:D
    Right I managed to sort the lil lights on top (seems I didn’t put enough of either in to fill it!)
    Now I have another problem, the d/washer isn’t working at all, ever load automatically switches to drain and then beeps and flashes 2 lights (F2 – Water Leakage
    Water is in the bottom tray
    Floater or float switch switches off the water valve and the electronic switches on the drain pump until pressure sensor reports that it is empty. There are numerous causes for this fault, but it all usually comes down to the fact that something, somewhere is leaking. To cure this you need to find the leak).
    You see the thing is this problem started after my daughter blocked the sink and once undone it is still beeping (even after resetting) How do I turn on the water valve for it to work again?
    Is the water valve the electronic box thing that’s attached to the water inlet pipe that’s under my sink? I’m so confused and its starting to smell because the sink water is flowing back into the dishwasher. 🙁
    Sorry for rambling and thanks!
    in reply to: Bauknecht gsx7551 manual #328906
    emz_77
    Lol, so I couldn’t spell on that day! I am still having problems, after filling both salt and rinse aid until full the lights remain on and just after releasing the dishwasher tablet the beeping begins and continues to beep on and off until the door is open. This is driving me mad!
    Thanks for the manual link, unfortunately it does not tell me what the beeping means.
    Thanks again! 🙂
