Enfoi Ros
  • Enfoi Ros
    Hi Tony,
    Sorry to bother you again, I ordered the sensor part 9590206 as suggested for my fridge freezer
    Liebherr CUN 3033 index 22/124,
    Service numb:0907994
    I did the search on Ukwhitegoods website shop for the 9590206. I carried out with the order. I have been delivered the item labeled 9590 206 -00
    but on the wire of the sensor is printed 6942626 by the manufacturer which is different from all of the sensors of the fridge freezer as shown per the following table: [TABLE=”align: center, border: 0, cellpadding: 0, cellspacing: 0″]
    [TR]
    [TD=”width: 143″] [/TD]
    [TD=”width: 101″]Compartment[/TD]
    [TD=”width: 121″]fixed on[/TD]
    [TD=”width: 99″]Manufact
    Ref[/TD]
    [TD=”width: 143″]color code[/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD]Sensor 1[/TD]
    [TD]Fridge[/TD]
    [TD]right wall[/TD]
    [TD]6942808[/TD]
    [TD]white[/TD]
    [/TR]
    [TR]
    [TD]Sensor 2[/TD]
    [TD]Fridge[/TD]
    [TD]against front wall[/TD]
    [TD]6942360[/TD]
    [TD]green[/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD] [/TD]
    [TD=”width: 121″] [/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD]Sensor 3[/TD]
    [TD]Freezer[/TD]
    [TD=”width: 121″]against the evaporerator[/TD]
    [TD]6942811[/TD]
    [TD]black[/TD]
    [/TR]
    [/TABLE]
    I contacted spares@ukwhitegoods.co.uk by email to raise my concern but they didn’t help in any way.
    Any suggestion will be appreciated.
    Regards
    Enfoi
    Enfoi Ros
    Hi Tony ,
    I just been delivered an evaporator sensor ordered on 6/7/19.
    the part I searched on the website is 6942811;
    the part i’ve been proposed by UKwhitegoods website shop has the code number 9590206.
    but today I have been delivered a sensor which part number is 6942626 !!!
    Is there a change to the manufacturer code number or is it a different item that I should return?
    Enfoi Ros
    Tony you are a gem! thanks a lot!
