Engine_Near
  • in reply to: Bosch WAS28461GB Dies in cycle #457466
    Engine_Near
    Re: Bosch WAS28461GB Dies in cycle
    Repeated power down & re-applied after 5 minutes again with same result; resuming on 8 minutes this time.
    Does this confirm electronic fault in timer as suggested?
    in reply to: Bosch WAS28461GB Dies in cycle #457465
    Engine_Near
    Hi electrofix.
    The machine powered back up immediately on reapplying the power. It initially showed 15 minutes remaining (the original full cycle time) then reducing it to 10 minutes which is about where it was in the cycle when it went off (assumed as I did not see exact time of failure).
    Whilst writing this it has gone off again but failed quicker than on the previous occasion.
    in reply to: Bosch WAS28461GB Dies in cycle #457464
    Engine_Near
    Thank you for the suggestion.
    I’ll go give that a try……
