Gaby Gabii
  • in reply to: Hotpoint 3C32 (new) stop after a few minutes #469110
    Gaby Gabii
    electrofix wrote:how long have you had it ?
    it’s brand new, i just bought it. never use it, i have that problem from first use.
    I can t understand why isn t an error code or sound or lid..if is something wrong.
    It seems like when i press play, the dishwashers do only rinse part…3-5minutes only. after drain all water and show End.. like program is done.
    in reply to: Hotpoint 3C32 (new) stop after a few minutes #469108
    Gaby Gabii
    electrofix wrote:short answer ring them
    I dont think it has a demo mode
    If you have just had it delivered and Hotpoint want to send an engineer then i would ring the retailer first and get them to swop it as its faulty when delivered
    They send me an engineer from Hotpoint in 2-3 days, should i return the product instead?
    in reply to: Hotpoint 3C32 (new) stop after a few minutes #469106
    Gaby Gabii
    electrofix wrote:i would select a quick wash or a rinse programme and see what happens
    it should
    pump
    fill with water
    start washing
    heat but only if its a wash programme ( not on rinses)
    then pump out
    if it fails anything ask for them to send you a new one as i assume you have just got it
    Just like that it s working.
    Pump
    fill with water
    Rinses
    water isn t heated
    then pump out
    Don t matter what program i select. Like that working on every program.
    So can be stick in demo mode or test cycle..idk, anything like that?
    No error code, no lid ..nothing.
    thank you!
