gareth_alexander
ParticipantRe: Hoover Six 1300 Sportswear AL130 – Error Number 2
Hi again,
I just replaced the pump, the impellor rotates now, however I still get error number 2 after a couple of minutes.
Any more ideas?
gareth_alexander
Thanks for all your help, the hose seems fine so I might be lucky but I will double check for rusting when I take out the pump.
gareth_alexander
If the pump impellor looks like a green cross, then it stays stationary for the entire cycle.
Does that mean that the pump has gone?
gareth_alexander
If I set the machine to program 29, which is a spin cycle, the cycle completes without a problem. If I set it to program 28, a rinse cycle, then I get error number 2 again.
gareth_alexander
Spin works, rinse doesn’t.
gareth_alexander
Its taken me a while, but I have now tested the water pipes. I have also cleared some items from the exit hose but that was as an aside.
The water is running freely from the inlet pipes. Can I take out the pump and check it or should I have a look at a filter somewhere?
