Harry Raft
ParticipantRe: Miele WT2670 water in drum after dry cycle
Thanks for all your advise btw
Harry Raft
Just did a quick test like you said, water was drained straight out, did a half hour dry all ok right until the very end (cool down period) when a bit of water appeared literally 10 seconds from the end seemed to drop from the top of the drum maybe????)
Harry Raft
Would this explain why it drains fine during a normal wash and only doesn’t drain during a dry? Been using it all weekend for washing a no issue. Only drying leaves water in the drum
Harry Raft
No haven’t used a colour catcher in over a year now, can I get to the sump hose to check?
Harry Raft
Hi yes cleaned the filter, the drain hose is 8 years old so gonna replace this to see if it helps
