Herr Jezza
ParticipantRe: Component ID – Liebherr
Well took another look this evening and job to know whether fridge evap plate has parted from liner – looks like a major strip down. Press the back of the liner and there is a small amount of give before before it bottoms out against something. Anyway, sadly think this one’s a dead’un.
Any forum rules on offering free spares – thinking mainly unit furniture to any members local.
Thanks for help.
Herr Jezza
Thanks for the info and liner tip. Hopefully will revisit the patient this evening and report back. Cheers.
Herr Jezza
Thanks for the reply and info.
Interesting, and makes perfect sense, that when not energised at least one section should cool, as I hard wired the comp to cut out all controls, left unit running, and neither section cooled. Comp motor readings checked out according to data sheet – windings resistance and run current spot on – so guess shortage of refrigerant prime suspect.
Now thinking probably not worth further effort. If lack of gas, will first have to find leak. Then not geared up for R600a – nitrogen purge, long vac down, etc, etc. Guess also there’s the possibility of either a circuit blockage or even damaged comp valves.
Would welcome any further thoughts. Scrapper?
Herr Jezza
ParticipantRe: Daewoo FRS – U20DBC Chilled Case Drawer
Might help visit:
http://www.4daewoo.co.uk/cgi-bin/search … 0DCB&part=Has a contact number for daewoo spares, then again maybe a partner company of buyspares. Good luck.
