Hi Kwatt,
I have checked the control board housing area and where the sensor wire and fridge temp control wire comes up through is still very wet as in the foam that protects the wires, I am tempted to see if the if I can remove the right hand side panel to gain access to the wires and the routing to dry it completely out. I checked the temps yesterday and the fridge was at 5,3c and the freezer at -18c but as soon as I had opened the door the unit started to warm back up and within 4 hours was at 8c fridge and -5c.
