Ian Bolton
  • in reply to: Neff U1421N2GB/02 Oven only heating up to 180 deg #447644
    Ian Bolton
    Re: Neff U1421N2GB/02 Oven only heating up to 180 deg
    Ok so I went for the element as I only paid £5.68 for it, and it was still the same, so I replaced the switch as you suggested, this hasn’t fixed it either, however the defect has changed so i imagine it was also faulty. I still have the same problem with the demand light staying on while the element cuts out (stops glowing red), however now the oven is actually getting hot. I don’t have a thermometer but i reckon it is actually getting up to temperature as it is a lot hotter than it was before, maybe it is being cut out by an overheat switch when it should be cut off by the demanded temperature
    in reply to: Neff U1421N2GB/02 Oven only heating up to 180 deg #447642
    Ian Bolton
    I have had a look at the switch and none of the terminals are black, they all look fine, is there anyway I can test it or will it just be a case of trying a new one
    in reply to: Neff U1421N2GB/02 Oven only heating up to 180 deg #447641
    Ian Bolton
    Thanks for the quick response, ill take a look and post the results
