Igloo_Vindaloo
ParticipantRe: siemens fridge freezerkgv3104
Hi jcbboy
well i just received my £10-50 bullet connector to short the sensor out, keep my fingers crossed it does the trick. Had I known I would have crimped it for 10p!!!!!!!!!!!!!!!
I have the same symptoms you decribed in a Bosch E-NR KGV-3104-BG/04 F.D. 7809/04014
Please can you tell me how to make up much a device?
I guess it’s just a question of shorting two of the connectors on the 3 pin connector on that couples to the right-hand side of the control board. Just not sure which, and don’t fancy experimenting, but I’m keen to get the fridge back in action asap, rather than waiting 2 weeks for a Bosch engineer. Not to mention the cost!Cheers
Tim
Cheers
Tim
Igloo_Vindaloo
ParticipantIf it’s “quite straightforward” I am keen to have a go at it myself, given suitable instructions – I am reasonably competent in electrical work.
Cheers
Tim
Igloo_Vindaloo
ParticipantRe: Siemens fridge/freezer help please.
Dave,
I’m in Reading (Berks).
The machine is a Bosch E-NR KGV-3104-BG/04
F.D. 7809/04014.Thanks
Tim
Igloo_Vindaloo
Mantasport,
Did you ever find the fault on your Seimens?
I have a Bosch KGV-3104-GB/04, which has the same symptoms you described.Cheers
Tim
