November 20, 2008 at 7:43 pm in reply to: hotpoint wd440 time saver / on off flash – stuck in loop #268928
inspector-71
ParticipantRe: hotpoint wd440 time saver / on off flash – stuck in loop
Boothstown. JCT 13 M60
I have ordered a new washer (not dryer this time!)I am going to dump the wd440 but since you are close, would you like it for spares?
November 19, 2008 at 10:28 pm in reply to: hotpoint wd440 time saver / on off flash – stuck in loop #268926inspector-71
according to the website, the first date is 28th. with a 3 year old I don’t think I can wait for them
November 19, 2008 at 8:29 pm in reply to: hotpoint wd440 time saver / on off flash – stuck in loop #268924inspector-71
i tested all the wires between the pcb and motor + the two black ones to the pump using a multimeter and there were no breaks.
the only thing that looked a bid dodgy was the pin circled in the picture. It is pretty wobbly. could this be the problem?
November 19, 2008 at 11:55 am in reply to: hotpoint wd440 time saver / on off flash – stuck in loop #268922inspector-71
with a multimeter, should it show a closed circuit if I check the plug going into the pcb. Or are the wires visible enough that I would spot a broken one.
I’m trying to get as much info as possible before i get home as I have no idea when I will get to look at it.Thanks for the help by the way, very much appreciated.
November 19, 2008 at 11:41 am in reply to: hotpoint wd440 time saver / on off flash – stuck in loop #268920inspector-71
ok. Out of interest, how does the wiring/connection cause such a fault since there appears to be some power to the motor as it spun this morning?
Is the pcb>motor connection purely a data interface? would it be because of some sort of bad connection or is there a resistance check or similar?
Just curious!
November 19, 2008 at 11:26 am in reply to: hotpoint wd440 time saver / on off flash – stuck in loop #268918inspector-71
ok, I will look at that when I get home. Maybe pull the plugs to the pcb and re-attach.
If the pcd is faulty, does that mean a hotpoint engineer visit? I presume I can’t just buy a pcb pre-programmed?
November 19, 2008 at 7:07 am in reply to: hotpoint wd440 time saver / on off flash – stuck in loop #268916inspector-71
there are five vertical lights on the left of the machine. The flashing one is the 4th of these from the top.
I left the machine off all night and switched it on this morning. I selected a wash program and it added a small amount of water, did a wierd extremely high rpm spin for a few seconds and then back to the flashing light and pump on.
January 5, 2007 at 7:21 pm in reply to: hotpoint wd440 making a noise when pumping out (I think) #199442inspector-71
ParticipantRe: hotpoint wd440 making a noise when pumping out (I think)
thanks guys. all fixed and loads of man points for me with the wife!
January 3, 2007 at 10:39 pm in reply to: hotpoint wd440 making a noise when pumping out (I think) #199441inspector-71
thanks guys, I see the oump and it’s definately coming from there. Will take it apart tomorrow,
inspector-71
ParticipantRe: hotpoint wd440 and drying times
thanks mate
