Ishi-Smith
  • in reply to: Smeg fab40ps fridge not cold #465689
    Ishi-Smith
    I’ll give it a try and see what happens
    thanks again
    in reply to: Smeg fab40ps fridge not cold #465687
    Ishi-Smith
    Hi K, thank you for your help so far.
    I have checked the damper and have seen it work when turning the fridge thermostat down and back up again.
    I noticed that when I removed the vent (part number 56547 on the diagram you sent me) at the front top of the fridge it is full of ice. Also when I opened the freezer door I noticed cold air started to come from the vent (I chipped a bit of the ice away) and when I closed the freezer door again it stopped. The fridge is still not cold though.
    any ideas?
    thank you
    in reply to: Smeg fab40ps fridge not cold #465686
    Ishi-Smith
    Hi K, I will take a look at the damper.
    thanks again
    in reply to: Smeg fab40ps fridge not cold #465684
    Ishi-Smith
    Hi K, yes we have defrosted the fridge freezer for 48 hrs and then switched back on. This hasn’t made any difference. Thank you
