jb-1969
ParticipantRe: How are the Bosch standalone electric 60cm cookers?
Ah, so it is for oven gloves or towel?
You do not have to use some peculiar “detachable handle”?If so that is a very good improvement over the “twist, fiddle, drop, scream, burn carpet tiles / linoleum / cat / feet”.
jb-1969
Oh, that is a point…
Conventional grill tend to be mineral insulated incolloy sheathed, which tend to be slow.
Whereas Creda Solarglo etc used a wire around a rod, supposedly heating faster (still slow, but not as slow).I assume the Bosch are the plain type. Just so I know.
That said the closed-door type grills are very fiddly to use re detachable handle and I think the Bosch is the same. Better off with a separate toaster, very little is grilled (only thing that could be is sausage which is actually oven cooked anyway).jb-1969
Sounds good.
Basically just checking nothing like the old AEG thermostat fault (correctable, but annoying) or controller failures etc.I do wonder how many people actually use the top of a double oven – except for grill, which tends to be slow to get started then burns stuff.
June 15, 2010 at 3:10 pm in reply to: Creda Solarglo 48331 Standalone main oven fan replacement #322410jb-1969
ParticipantRe: Creda Solarglo 48331 Standalone main oven fan replacemen
Done, fitted, working.
Not an easy job, but a whole lot quieter.Took a long time to get all the fluff out, which appears to have been shed in a blanket from the upper fan.
June 15, 2010 at 1:21 pm in reply to: Creda Solarglo 48331 Standalone main oven fan replacement #322409jb-1969
First problem fixed.
The hob & sides only need be lifted 0.25″ to lift the back panel off.New problem.
The old fan fits through a shaft-sized hole in the oven chassis, and will obviously not slide off with the circlip & washer attached to it.
You have to use circlip pliers to remove the circlip & washer, then slide it out of the oven.Hilariously the new fan employs a circlip and washer, only the washer is bizarrely has been press fitted and will require a puller or cutter to get it off.
It makes me think the latter ovens have a large hole – clearance for the washer/circlip assembly rather than just the shaft as mine has.
I have never seen so much dust in an appliance, not even multi-decade old TVs. Cleaned the top fan.
Now to cut that washer off.
Bagging & taping the rest so no filings get near it. My puller is too large for such a tiny item. -
