Jim Hutchins
  • in reply to: Beko DSC85W, no heat, but checks all ok? #481303
    Jim Hutchins
    Thanks so much for this. My NTC R values don’t seem wildly off, considering it’s closer to 10-15°C in my garage where the drier is.
    I’ve just (carefully) checked for voltage on the heating element’s supply lines, and I can’t find anything there whilst the machine is running. Am I right to assume from this that the control board is failing to deliver?
    in reply to: Beko DSC85W, no heat, but checks all ok? #481301
    Jim Hutchins
    electrofix wrote:you are reading across 2 elements
    you have 2 elements
    1600 W 32 ohm
    700 W 73 ohm
    make sure both are there
    Thanks for that. Yes, you’re right; have double checked and exactly as you say: 104 ohm total, 32/72 split.
    Have also checked the NTC thermistor at the front (under the lint filter) and that’s reading about 14k ohm cold, drops when heated.
    Can’t find anything out of the ordinary, but still no heat.
