Jim S
  • Jim S
    Re: Bosch SGS43C12 – lower spray arm not rotating (no water)
    Yep you were right gegsy.
    The BSH guy came back and decided it needed a new “module” (PCB). He came back again yesterday to fit it (3 visits to fix 1 problem!) and now all is well, the lower spray arm is spinning as it should.
    cheers
    Jim
    Jim S
    Hmm, I was too hasty with my “seems fine” judgement. The fault isn’t fixed – still the same problem, no water supply to the lower spray arm.
    I have to take half a day off work to let an engineer in, so I’m annoyed at the time wasted yesterday. Another service engineer is due next Thursday, hopefully this one will have more of a clue.
    Jim S
    Just for info, this morning the BSH engineer found that the diverter motor wasn’t spinning because the plastic wheel was jammed somehow. So he replaced the whole unit (instantaneous heater and diverter motor). Now seems fine.
    This is the second time that this dishwasher has needed a repair under warranty. I’d guess the two trips have cost Bosch more than the entire original purchase price of the machine (£160).
