john-t
  • in reply to: Belling 450R fan oven problem #380411
    john-t
    Re: Belling 450R fan oven problem
    Hi RocketMan
    I have done as your suggested with POWER OFF, and here are the results.
    Tested across the fan oven switch terminals.
    Switch off Resistance 84.4
    switch on Resistance -00.1
    Tested across the fan terminals with fan connected
    Oven Switch off Resistance 60.6
    oven switch on Resistance 16.9
    Tested across the element terminals with element attached
    Oven switch off Resistance 23.5
    Oven switch on Resistance 16.8
    Element tested when unconnected Resistance 23.6
    Not sure where the TOC is but I have found something between the switch and the element on the live side. It is just like a small in/out link on a bracket with terminal either side.
    I get a resistance reading of -00.1 across the terminals of this part.
    Does this help you or anybody else and what next ?
    in reply to: Belling 450R fan oven problem #380409
    john-t
    Red indicator light not showing, Timer is set to manuel and there is continuity through to the element and fan.
    I have seen on another spares website CKR5774 Thermal cut out.
    Could this be the problem.
