Re: Smeg DWI 710 E1
Hi there
I appear to have a very simiar fault – did you get any advice on how to fix?
I think the error lights were #1 flashing and #5 constant (not sure) and have never been able to get this sequence to happen again.
Fault is that the machine appears to freeze within 2 mins of starting a new cycle. I can hear water pumping in but it never progresses to a wash cycle, appearing instead to freeze with nothing happening. When I open the door I the water heating element is red hot with little or no water in the bottom of the machine.
I’ve followed Penguins advice on resetting the machine however it keeps freezing on all cycles. I have used manufacturers guide of press and holding the programme selector for 5 seconds to move it to the end of the cycle before trying again. I then get lights 4 & 5 Flashing. Please help!
