Junk Yard
ParticipantI put it in the best I could but it would not go in all the way in. I have tried it for several days at different tempratures. with a thermomitor in a bucket of cold water and it seams to freeze up even when on the minimum setting
Junk Yard
ParticipantI will contact them about it
Junk Yard
Participantelectrofix wrote:what have you powered from mains power ?
your old motor ?Dave
No i have powered the new motor i just bought
Junk Yard
Participanti have just tried powering it direct from main power. and nothing! no turning no sound
Junk Yard
Participanti though i would test it on its own first. by wiring direct to 240v.
Which terminals are + and – ? or dose it not matter since it is AC?
Junk Yard
Participantthat is what I have done pulled the old pheli out, that in the new one you can see in the photo
Junk Yard
Participanti have drilled round it and pull it out, however i can not get the new one to go in as it will only go in about 4″
September 23, 2025 at 12:15 am in reply to: temperature not working right of domestic fridge #493621Junk Yard
Participantkwatt wrote:You cannot cut it or kink it in any way! If you do, it’s done and will never work as that phial is filled with a gas that expands and contracts to operate the switch in the thermostat. Hence, if you damage that phial, the thermostat is knackered.
It will come out, they are all replaceable but how easy or hard it is varies.
But which end dose it come out? though the inside of the fridge (see photos) or other end where we dont know?
Junk Yard
thats the only one i have seen thats not 230V
how are you going to stop the motor from turning all the time the unit is plugged inyou would need to find a switched feed
What do you think the switch voltage is? do you think it is reduced? if so then would a relay work; using the switch power and the main 230v power
Junk Yard
ParticipantIt goes though the wall of the fridge and will not pull out!
Can i not cut the blue bit of the new one and join it to the end of the old one (as seen in photos)
Also in the last photo, is a photo of the end of the pheli from the new one. what dose the round bit do?
Junk Yard
Participantelectrofix wrote:ok sounds like possibly
https://www.amazon.co.uk/Turntable-Synchronous-GAL-5-30-TD-Microwave-Accessories/dp/B09KXT8ZV5
From memory it was 40V. But I will check it again later on
Is the voltage the only differance in that one and the one I just bought from the “white goods” shop?If its the voltage being an issue, then can i just find a 240v supply from the microwave somewhere ells? and wire the plug from the motor to it? (presuming that the rest of the microwave runs on 240v)
Junk Yard
Participantelectrofix wrote: correct
did you check the coil of the old motor ?
is it open circuitjust trying to work out if its an electrical or mechanical problem
I dont understand how do you check the coil
Junk Yard
Participantif my plug is putting out 40V and the motor is a 240V motor, then I guess it wont turn!
Junk Yard
Participantelectrofix wrote: ok
what arrived today , i assume a new motor , where did you obtain it from ? and did it give a voltage ?
you will never turn these by hand as its geared insideDave
well it would not turn when connected to the electric plug either
Junk Yard
Participantelectrofix wrote: if its 40v you have no real chance of getting a new motor
even if its 240v AC it may be difficult as these motors maybe common but the output shaft can change between models. I get round it by keeping used motors to allow me to strip them and swop the internal parts
suggest you measure the voltage again and see what you get
Before n=reading your post!
It arrived today and i tried it before, but it dose not turn! it dose not turn by hand or when it is connected to the electric plug
