Kieran Delahunt
Participantwith it being f6 and temperature sensor related, would it be the temperature sensor?
Kieran Delahunt
ParticipantSo, I now get f5 with the original board and f6 with the new one even after switching each time and time again….
Very strange. Are there other parts that might be causing this because I’m reluctant to say the temperature sensor is now gone and buy another.
Kieran Delahunt
ParticipantI’m now just getting an F6 error, is this thing just knackered?
Kieran Delahunt
Participant[USER=”2″]kwatt[/USER] More clarification, just to get your opinion. I have a multimeter on the connections to the valve, the reading fluctuates between -10v and 8V from the off. Does that suggest a current leak in the system somewhere and would you think it will be the main PCB still?
Kieran Delahunt
Participant01693668001731420049
Kieran Delahunt
ParticipantDo I provide it here or somewhere else?
Kieran Delahunt
ParticipantOkay, I can verify the wires to the valve are not producing anything. What could that be?
Kieran Delahunt
ParticipantThanks K, water is indeed getting to the valve just not past it. I’ll get a multimetre and test the valve but it has to be this. Do you know what could be the issue if there’s no voltage at the valve?
Kieran Delahunt
ParticipantHi [USER=”2″]kwatt[/USER] , any other ideas – it’s not getting past the new water valve. I’ve had the hose off the back and set it on a cycle but nothing comes thorugh. Could it be a logic board somewhere?
Kieran Delahunt
ParticipantThe water valve hasn’t worked, fingers crossed for the flow meter
