Krazy Killer
  • in reply to: Bosch WAE24363GB/5 Washing Machine #365105
    Krazy Killer
    Re: Bosch WAE24363GB/5 Washing Machine
    So my problem as gone now. The motor is spinning to full speed now. I suspect that I had not cleaned up the armature properly and carbon dust from the brushes was partially shorting the windings. This sort-of fits with Martin’s coments too?
    in reply to: Bosch WAE24363GB/5 Washing Machine #365103
    Krazy Killer
    So I have the same problem with my Bosch WFO2864GB/01 : wash is fine, spin cycle goes from 11->8mins ok but DOES NOT get up to full spin speed. It then jumps from 8->1min and finishes. When it is empty it spins faster and goes until 7 mins before finishing.
    Suspect the balance as I can see the out drum moving quite a lot when it trying to get to speed.
    I changed the motor brushes over the weekend and (for various reasons) removed and cleaned all the out flow plumbing (drain sump, pressure chamber & hose (not sensor), pump filter, container return. What could I have effected to cause the in-balance?
    @martin
    : what do you mean by motor insulation?
    TIA.
