Re: Maytag GZ2626GEKB Fridge/Freezer Water not shutting off
Hi, thanks for the reply. The micro switch seems to be working OK as pressing the water pad it tries to dispense water (you can hear the pump trying to dispense) and shuts off OK when releasing. Turning the water on at the water isolation tap means that the water floods out of the filter head unit in the roof of the fridge so whatever is meant to shut off the water at the filter when the pump stops is not working. There does not appear to be an electrical connection to the filter head, just two water pipes one from the mains and one from the bottom of the fridge.
