Laurence Hillyard
Viewing 1 post (of 1 total)
  • in reply to: Miele Novotronic Premier 500 : Rinse light flashing #475589
    Laurence Hillyard
    I have a similar fault to this. on what sounds like the same model with the same control PCB.
    Machine correctly lets in water and starts wash. The drum turns (Possibly too slowly). After a couple of minutes the wash stops, the machine drains and proceeds to the flashing rinse light.
    The wash stops earlier if there is a wash load in the machine. I am using an old bath towel.
    I have replaced the motor brushes and am getting the ~2.5 ohms across the motor windings.
    I am suspecting that the main control PCB may have a similar fault to the one fuse and relay fault on the EL200 board.
    I have access to a surface mount repair facility but with no circuit diagram am stuck.
    If any one has any ideas as to what to look at next or as to if there is anybody who can test the PCB I would be grateful.
    We have replaced the machine but as it still looks great inside I would hate to throw it away.
    Laurence
