Re: Stoves Oven and Hob – Repair or Change?
I tested the oven as it was not cooking food properly. I think the underlying cause is that it is taking far too long to reach the set temperature. My current workaround is to set the temperature about 2 – 3 gas marks higher than needed and turn the temperatgure down to the correct setting after about 30 minutes. Of course this wont work when you need a very high setting to start with.
