marc.knuckle
ParticipantIt’s inside. Behind the second up from the bottom tray.
marc.knuckle
ParticipantNo it actually only felt like rubber when i squished my finger on there.marc.knuckle
ParticipantThe white pipe is what i cleaned a bit and water came out and the grey hole is on the inside but not inline with the pipe
marc.knuckle
ParticipantIt’s at if there is a rubber plug in there when checking from the top but it’s not aligned with what I’m seeing from behind so it might not even be the drain but i can’t see any other holes from the inside.
How do i post a picture and I’ll put it on here?
marc.knuckle
ParticipantNo we haven’t had any water in the dispenser for a while and it’s not hooked up to the mains so it’s nothing to do with that part.
I only mentioned this at the top as that bit I’ve given up with and stopped using.
It’s to do with the white pipe at the rear and/or the inside hole.
As mentioned i have photos bit don’t know how to post on here.
marc.knuckle
ParticipantThanks, i realise you don’t get paid and i appreciate the response. Simply seeing all the latest threads with little or no replies made me think the forum was abandoned. Hopefully i may get further forward now thanks.
marc.knuckle
ParticipantNot sure the value of this forum when there’s no response from anyone including moderators. It seems all the latest posts are lacking any support.
marc.knuckle
ParticipantAny help with this guys?
