mark.r.cullen
  • in reply to: Zanussi ZCE7610W light went out, oven went cold #369463
    mark.r.cullen
    Re: Zanussi ZCE7610W light went out, oven went cold
    A late follow up: Got a new thermostat for the main oven and it has fixed it. Pretty straight forward to fit.
    Suspect top oven is the same problem, but we only use that for the grill so it can wait 🙂
    New problem though, the front left hob seems to be falling back to “2” when set on “6”. It will heat on full power for about a minute then drop down to “2” and stay there 🙁 Now about to search the forums, unless anyone knows quickly what the problem might be?
    Cheers,
    in reply to: Zanussi ZCE7610W light went out, oven went cold #369462
    mark.r.cullen
    Sorry for the confusion. Disregard my last post.
    The main fan oven fan *does* work.
    The light *inside* the bottom oven went out once, but came back on a few minutes later of it’s own accord, and hasn’t happened again yet.
    After using it a few more times, with a brand new oven thermometer, it seems like maybe there is something up with the thermostat(s).
    The top oven didn’t seem to register that it was hot at all. I set it to 180C and left it for 10-15 minutes and the red light next to the dial was still on to say it hadn’t reached temperature. The thermometer was reading 200C. I twisted the dial all the way back around to the lowest setting, and the light was still on (thermostat still thought it was stone cold?).
    The bottom oven seems to register that it’s reached temperature, and the red light next to the dial for it goes out, but seems to keep on heating up. I had it set to 160C, and it reached 220C. The red light kept going on / off (which I know is normal, but it was 60C higher than it should have been).
    The top oven seal is also ripped slightly and could do with replacing.
    We would be very grateful for any advice / part numbers to get the cooker back in working order 🙁
    Mark & Amanda
