December 18, 2013 at 3:47 pm in reply to: Oven FFP403X Type MR03. – new element tripping whole house #406507
Marty_K
ParticipantRe: Oven FFP403X Type MR03. – new element tripping whole hou
Cheers K – will do. 🙂
December 18, 2013 at 2:49 pm in reply to: Oven FFP403X Type MR03. – new element tripping whole house #406505Marty_K
Hi K
Many thanks for your reply – sounds liek a switch issue as you say, as it’s only tripping after being switched off. Is there likley to be a lose wire or something behind teh siwtch I can access or would it be a whole switch replacement do you think?
Many thanks for your help.
November 20, 2013 at 1:56 pm in reply to: Candy Built-in-Fan over – Model PL2230/3X Element replacemen #404784Marty_K
ParticipantRe: Candy Built-in-Fan over – Model PL2230/3X Element replac
Nice one!
M
November 20, 2013 at 1:45 pm in reply to: Candy Built-in-Fan over – Model PL2230/3X Element replacemen #404782Marty_K
K
Forgot to ask – does it matter too much if the element is 2200w or 2500w – that one you highlighted sounds very good value for money.
November 20, 2013 at 1:00 pm in reply to: Candy Built-in-Fan over – Model PL2230/3X Element replacemen #404781Marty_K
K
Many thanks for all your help here – it’s much appreciated. Now for tacking that element!
The plate showing model number had a wee bit of grease on it – should have used a better torch! 🙂
November 20, 2013 at 12:24 pm in reply to: Candy Built-in-Fan over – Model PL2230/3X Element replacemen #404779Marty_K
Hello
I’ve now found the model number of the oven – it’s FFP403X Type MR03.
Any help about element extraction much apprecaited.
Cheers
MartinNovember 19, 2013 at 4:01 pm in reply to: Candy Built-in-Fan over – Model PL2230/3X Element replacemen #404778Marty_K
Thanks for clarifying – I’ll seek the elusive rating plate tonight!
The instruction book that cam eiwth it is next to useless!
Cheers
MNovember 19, 2013 at 3:49 pm in reply to: Candy Built-in-Fan over – Model PL2230/3X Element replacemen #404776Marty_K
Hi Kwatt
Thanks for your reply – I couldn’t see a rating plate but will have a good look again tonight. There was a guarantee slip I found that came with it (out of date and all in italian) which quoted model PL 40 AX and a further code no 33800588 – would that be the oven make? If not I’ll re-check later.
Cheers
M
