Hi again Tony thanks once more, I’ve see the Torx screw on the bottom hinge with the pin sitting in its slot. I’ll take the door off later today and check upper pin. Thanks once more
Hi Tony many thanks for your reply.
ive checked the switch and no problem. The door will close if I lift slightly before closing then athe fridge clunks towards top of fridge. I suspect the upper hinge I’m going to remove the top plastic cover and examine more closely
thanks again
