mike low
  • in reply to: Hygena Ignition Switch #123491
    mike low
    Re: Hygena Ignition Switch
    The problem I’ve got is the original owner of our house left no manuals for the appliances, would you know the best way to get to the model number on the hob ?
    Mike
    in reply to: Hygena Ignition Switch #123489
    mike low
    I need the plastic button and also the switch the button sits on, the one I have has seized so when you press the button the switch does’nt move so no gas ignition. The switch is fixed onto the hob by a small bolt.
    Hope this helps !
