Mitchell Schwartz
ParticipantI also found a you tube video explaining the same hack! Thanks again. It seems to be working good.
Mitchell Schwartz
ParticipantThank you so much!
Mitchell Schwartz
ParticipantAre there any specific details or specs we should know to get at the timer?
Mitchell Schwartz
ParticipantOK, would appreciate it as I have a local repair tech coming over to assist me to remove the oven, and to open it up to get to the timer.
Mitchell Schwartz
ParticipantI should be able to get you a photo before 2pm on Friday. I hope that you will be available to respond around that time. Is there a direct email that we can use?
Mitchell Schwartz
ParticipantOK,m perhaps I can schedule it a bit earlier on Friday, but to get you the photo by about 2:00pm. Is there another email I can reach you at?
Many thanksMitchell Schwartz
ParticipantDave, if I schedule to do this on Friday, are you available to answer us real time? Say around 2-2:30pm UK time?
Mitchell Schwartz
ParticipantOK, I’ll try to do this and get back to you. Thanks for your help Dave.
Mitchell Schwartz
ParticipantOK, but can you provide more detailed info on how remove the unit, and instructions on how to jump the terminals to bypass the timer? I have a technician that can come to do the work, who is at least familiar with these appliances. I can coordinate the work so that we can catch you during work hours. But aside, knowing the model #, do you think a replacement timer is avialable?
Mitchell Schwartz
ParticipantThere is file restriction size of 19 KB and my photo is larger much than this. Can the restriction be eliminated or increased a suitable amount to allow me to upload?
Mitchell Schwartz
ParticipantWhat other info is required? According to the product rating plate the model # is ESO 313 (the manual I have lists model # ESO 310/312). The serial # appears to be 62 E000042
