mj-uk
  • in reply to: Help! Dishwasher lights are on but nothing happening! #386046
    mj-uk
    Re: Help! Dishwasher lights are on but nothing happening!
    Thanks, will check this weekend – no time so far!
    It seems to lock in place ok, so maybe a loose/broken connection? Is it reasonably easy to access if I take the front panel off?
    in reply to: locating/changing lower element on IKEA/WH FCEM6 oven #291185
    mj-uk
    Re: locating/changing lower element on IKEA/WH FCEM6 oven
    *@{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}#!
    Any idea if it’s relatively straightforward to access/change once the oven is out, or is it a job for an expert?
    in reply to: locating/changing lower element on IKEA/WH FCEM6 oven #291183
    mj-uk
    It’s a psuedo multi-function oven – static upper+lower heating, static upper+lower heating with fan (which we normally use), grill, and a symbol with a fan and what looks like a water drop underneath it (which I guess is just fan but why would I use it?!?).
    My first thought was a fan element, but on taking the cover off the fan I discovered there isn’t one – I guess it’s “fan-assisted” rather than a true fan oven.
    On searching spares there isn’t a fan element listed for this model number, only the grill/top oven element and the lower element.
    The problem is, the lower element is “hidden”. The bottom of the oven is just a flat base, no removeable section, no vents, no sign of a lower element at all. I can’t quite figure out how it works – hence the posting.
    I’m guessing I going to have to pull the oven out, but was hoping to avoid that – I have visions of it being a very awkward job.
    Any other thoughts?
    thanks
