Re: Indesit W123 UK flashing error code nine – now three
The rotating dial is a fault message, the washer is trying to tell you it has a problem. The actual fault is revealed by the number of flashes of the red LED. For example, 10 flashes means a problem with the pressure switch, 3 flashes means a faulty module.
To reset the module, switch OFF at the mains, turn the dial to the next black dot, switch ON at the mains.
I got a second-hand module for £20 from a back-street shop. It worked fine. Think re-use, re-cycle, save the Planet (and your cash)
