Re: HOTPOINT WASHER WM25 CLONK DURING SPIN
Hi, thanks for the advice on the drum support. £30 sounds better than £300 to replace this side of xmas so I may go down that route unless special tools are needed. Could you please bullet point how i go about it, or confirm that there is likely to be similar responses elsewhere on the forums. only basic guidance needed, i’ll work out the rest, but i dont want to for example take the front off if not necesary. thanks for your prompt response. neil
