Nic28
Viewing 1 post (of 1 total)
  • in reply to: Diplomat ADP8322 upper spray arm not rotating #263526
    Nic28
    Re: Diplomat ADP8322 upper spray arm not rotating
    Thanks for your replies.
    When the problem first emerged I checked the feed pipe and it was disconnected but after re-connecting the issue still remained (i.e. upper spray arm still not rotating.
    Is it possible that the feed pipe needs replacing (nothing obvious to my eye to suggest this)?
    If I am looking at pump fault (and yes there is a fair amount of water on the floor of the dishwasher if you open mid cycle), what is the success rate/life span of the dishwasher after installing a new pump?
