Nic_Collins
  • Nic_Collins
    Re: Samsung RL39WBSW Fridge/Freezer – Mini Glacier in Freeze
    Thanks, I’ll try that……..I can just stick the contents of the freezer outside as it hasn’t got above minus 4 here today!!!
    in reply to: Transformer for Illuminated Bathroom Mirror – ETC 150R 11.5v #331387
    Nic_Collins
    Re: Transformer for Illuminated Bathroom Mirror – ETC 150R 1
    Thanks Martin, I’m pretty sure I’ll end up just getting an equivalent transformer as there’s a fair bit of space behind the glass to modify the fitting.
    in reply to: Hotpoint CDT40 Dryer Rumbling/Heavy Rattling Noise! #306187
    Nic_Collins
    Re: Hotpoint CDT40 Dryer Rumbling/Heavy Rattling Noise!
    Just had the back off and as you suggested the bottom fan is slipping on the spindle. I presume this is just wear on the plastic that has made it loose as I can see no damage. I’ll order a new one although in the meantime I’m tempted to bodge a repair by wrapping the spindle in something to stop it slipping! My only concern in doing that would be that the temperature is quite high in that compartment so it would have to be heatproof!
    in reply to: Hotpoint CTD40P No heat? #261948
    Nic_Collins
    Re: Hotpoint CTD40P No heat?
    Well it’s fixed, a very simple job (except for the kitten playing with the screws while it was dismantled!) so thanks for the advice.
    in reply to: Hotpoint CTD40P No heat? #261947
    Nic_Collins
    Thanks, I’ll let you know how I get on!
    in reply to: Hotpoint CTD40P No heat? #261945
    Nic_Collins
    Of course if I’d done a ‘search’ first I’d have been able to answer most of my questions!! It would appear that I need to try a thermostat kit rather than a new element, any DIY tips on disassembly and re assembly of the machine will be much appreciated!
    Nic
