April 16, 2025 at 7:13 pm in reply to: Bosch HBC84E653B/04 – Microwave fails after 3 secs – replaced Mag, Inverter, fuses #492550
Nick_S
ParticipantOK thanks – anyone else know please?
April 16, 2025 at 6:12 pm in reply to: Bosch HBC84E653B/04 – Microwave fails after 3 secs – replaced Mag, Inverter, fuses #492548Nick_S
Participantthanks – cant get to doing what you suggested until the weekend so will update next week
Still keen to understand how to get the machine into Debug Mode – does anyone have any ideas? – cant find this on the web so I am hoping someone knows this
April 15, 2025 at 8:58 pm in reply to: Bosch HBC84E653B/04 – Microwave fails after 3 secs – replaced Mag, Inverter, fuses #492546Nick_S
ParticipantI replaced all 4 relays in the bank with new ones on the power board
there is another one by itself – any idea which one it would be ?April 15, 2025 at 7:31 pm in reply to: Bosch HBC84E653B/04 – Microwave fails after 3 secs – replaced Mag, Inverter, fuses #492544Nick_S
Participantthanks Merv – fuses triple checked and both are OK
door switches checked and jumpered but will triple check these again (on my to-do list)
Keen to understand how to get the machine into Debug Mode – any ideas?
April 11, 2025 at 8:45 pm in reply to: Bosch HBC84E653B/04 – Microwave fails after 3 secs – replaced Mag, Inverter, fuses #492542Nick_S
ParticipantHi Merv – I assume they are working units as they were new and they were the correct part numbers – the power board does not seem to be supplying 240V to the Inverter so I am not sure that the inverter or the magnetron are the issue as they are downstream of the lack of 240V
April 11, 2025 at 11:00 am in reply to: Bosch HBC84E653B/04 – Microwave fails after 3 secs – replaced Mag, Inverter, fuses #492540Nick_S
ParticipantHi Merv and Dave
Thanks for your replies
I have checked the fuses and replaced them where they were blown and also the capacitor that was bulging
BUT I don’t have any voltage on the inverter supply cables
Thanks for the logic flow charts – they should be very helpful
Any ideas how I put the machine into the debug mode?
Also is there a voltage trace diagram across the power board that I could use to determine what has stopped working ?
April 9, 2025 at 6:59 pm in reply to: Bosch HBC84E653B/04 – Microwave fails after 3 secs – replaced Mag, Inverter, fuses #492535Nick_S
Participantthanks Dave – very helpful and speedy – will check tomorrow
April 9, 2025 at 6:32 pm in reply to: Bosch HBC84E653B Combi Microwave section runs for 2 seconds before shutting off #463893Nick_S
ParticipantHi @electofix
I have just seen this same post thread from a few years ago
I have a similar problem with the same model, an inbuilt Bosch HBC84E653B/04 combination microwave, grill and fan oven (about 12 years old)
All functions (both the grill and fan oven) work apart from the microwave
The symptom is when you hit the start button on the microwave, it starts to count down and then stops after 3 seconds with nothing heated up.
I have checked the door safety switches and they are all OK
I have replaced the Inverter and the Magnetron with working units
I have checked the circuit board and replaced both fuses and the then the bank of relays
But the problem persists
I even found another unit on eBay and did some checks on that (also blown fuses which I replaced) and then did some major component swapping
and the problem still persists
I cannot find any information on the Initiation checks but see that failing after 3 seconds seems to be a common fault
I am in a similar situation to Paul_A in that a replacement microwave costs about £700, and a combi would be more
However that is only 1/4 of the problem as my wife wanted 4 units when they were installed 12 years ago (2 ovens, 1 combi microwave and a steamer)
Now that the combi microwave does not work and the replacement units have a different appearance – so I would have to change all 4!!! at a stupid costs if they were to look the same and all work
Do you know what else is checked in the initialisation? heat sensors etc that could be causing the microwave to fail?
thanks Nick
