nova_turbo
  • in reply to: Help With Beko CG964 #240584
    nova_turbo
    Switched it on at 2:00pm today and although the compressor is running not even the freezer is working now!
    Can I pressume its dead? Is it worth calling an engineer?
    in reply to: Help With Beko CG964 #240583
    nova_turbo
    Re: Help With Beko CG964
    Thanks for your help!
    Is it normall for the fridge to be making noises even after being switched off for a few hours?
    in reply to: Help With Beko CG964 #240581
    nova_turbo
    expertcat wrote:all i can say is make sure that the freezer is fully defrosted and then get the freezer fairly warm as if the refrigerant is R134a it might clear the blockage in the refrigerant.
    If it doesnt work then you will either have to let the unit die in fridge freezer heaven or replace it.
    Yes, it’s R134a. Would a blockage cause the freezer to be ok or and the fridge not to be? Doesnt the air from the freezer go into the fridge? or is that another model?
    Fingers crossed a defrost works!
    in reply to: Help With Beko CG964 #240579
    nova_turbo
    expertcat wrote:theres no panel in that beko as its a standard fridge freezer.
    Thanks for the reply. Other than leaving it off for 48hrs and switching it back on is there anything else I can do?
    in reply to: Help With Beko CG964 #240577
    nova_turbo
    I’ve now switched the fridge off and left it defrosting.
    Could anyone tell me what panel I need to remove?
    Rob
