Re: Indesit IDL 40 Error
No…………. filters all clean.
Found the problem though – the flashing light indicates the float overflow switch has kicked in – ie the machine has a leak – the bottom tray is full of water when you tilt it.
Traced leak back to the top spray arm feed pipe. The thread must have been overtightened when assembled as it’s split. Have reassembled minis the top tray guide and machine completed a full wash cycle 😉
So just need to order a new top spray arm feed pipe and refit with top tray guide.
Job done.
Thanks for your response helo_75
