April 23, 2020 at 7:38 pm in reply to: Bosch HBC84E653B Combi Microwave section runs for 2 seconds before shutting off #463879
Paul_A
Participantvchook wrote:Do you mind me asking where is the fuse located as I have exactly the same problem. Thanks
Looking from the back its on the panel on the left.
On mine it was a ceramic fuse so it was difficult to tell it was blown, so you need to either test or replace it..October 18, 2019 at 1:37 pm in reply to: Bosch HBC84E653B Combi Microwave section runs for 2 seconds before shutting off #463876Paul_A
ParticipantMany thanks again..
October 18, 2019 at 1:01 pm in reply to: Bosch HBC84E653B Combi Microwave section runs for 2 seconds before shutting off #463874Paul_A
ParticipantAfter you asking if I have checked the fuse, I went back and double checked and lo and behold there was a 10a fuse blown and replacing it has restored normal operation.
A bit annoying I didn’t double check first time as that would have saved me £120 in parts I didn’t need, though I guess one of the parts I replaced might have blown the fuse.
But, I now have a piece of plastic which I can’t remember where I removed it from, so is there someware I find a layout diagram to see where it goes as I can see anywhere obvious..
October 18, 2019 at 11:56 am in reply to: Bosch HBC84E653B Combi Microwave section runs for 2 seconds before shutting off #463871Paul_A
ParticipantYes, but the microwave does come on, then shuts off, which I wouldn’t expect with a blown fuse..
Is there a way of over-riding the control panel to force the microwave to run as I guess that’s the next item..
October 18, 2019 at 11:35 am in reply to: Bosch HBC84E653B Combi Microwave section runs for 2 seconds before shutting off #463869Paul_A
ParticipantBack to square one I’m afraid – replaced the inverter and it’s still the same – runs for 2 seconds then stops..
So I’ve replaced the magnetron and the inverter, so can anyone suggest what I try next please..
October 16, 2019 at 12:38 pm in reply to: Bosch HBC84E653B Combi Microwave section runs for 2 seconds before shutting off #463868Paul_A
ParticipantMany thanks dave – fingers crossed I’ll have a working microwave again..
October 16, 2019 at 12:14 am in reply to: Bosch HBC84E653B Combi Microwave section runs for 2 seconds before shutting off #463866Paul_A
ParticipantMany thanks Dave..
Do you have any suggestions how I find the Panasonic equivalent to the Bosch part please..
