redland_doug
Viewing 1 post (of 1 total)
  • in reply to: Beko AB910S woes #355744
    redland_doug
    Re: Beko AB910S woes
    Beko did get back to me – very helpful too.
    The part I require is the one you mention. Beko confirmed the part number is 4216600385.
    Its located in the rear of the freezer compartment, about halfway up the rear wall. There is a small grill on the left hand side – its just behind there. If you don’t have the ice maker option then its simply a case of taking off the rear panel of the freezer compartment (few screws) and changing it. If you’ve got the ice maker, then its considerably more complex, because all that has to come out first. Hope this helps anyone else who gets this error.
    PS part is widely available, roughly £10 delivered.
    Cheers,
    Doug
