rob yarrr
  • in reply to: Bosch Avantixx ‘check water’ light (model SGS45A02GB) #399960
    rob yarrr
    Re: Bosch Avantixx ‘check water’ light (model SGS45A02GB)
    sounds the same as mine, tip it on its back, not the door side and take off the metal base, might be a little earth connector on it so be carefull, pump is just a screw fit on one, i’ll assume it has abit more glass in jamming it, the pump impeller has some resistance to it, if it doesn’t work after that, and you’ve put the correct connectors back on in the right place, then its a new pump, only like £30.
    in reply to: Bosch SGS45C02GB problem #398894
    rob yarrr
    Re: Bosch SGS45C02GB problem
    new drain pump seems to have done the trick.
    in reply to: Bosch SGS45C02GB problem #398893
    rob yarrr
    Andy jones wrote:Did you check the housing before put pump back on. Sound like a blockage if not sound like you need a new pump
    yup checked everything it can be, anyone know where i can get a pump from and for a good price? thanks
    in reply to: Bosch SGS45C02GB problem #398891
    rob yarrr
    yeh its been off and nothing is in there which is odd, i assume this is the same pump that you can see in the left of the sump yes?
    in reply to: Bosch SGS45C02GB problem #398889
    rob yarrr
    is there anyway to check the drain pump ? it gets to 16 mins, a relay clicks and then you hear something like the pump trying to turn but sounds like its catching and then stops and the check water light comes on
    in reply to: Bosch SGS45C02GB problem #398888
    rob yarrr
    well took the facia off and the only way to the circuit board is to take it apart in a way i don’t think it’ll go back together
    is there anything else that could be up with it ?
    in reply to: Bosch SGS45C02GB problem #398886
    rob yarrr
    Martin wrote:Take a look at the circuit board as I think there may be a dry joint?
    how do i go about doing this ? thanks
    in reply to: Bosch SGS45C02GB problem #398884
    rob yarrr
    stevebunyan wrote:Have you checked the sink end of the drain pipe for blockages?
    yeh is fine, i took it off the washer and swilled it through with boiling hot water, it empties out of the wall like normal from the sink, from what i can see the water isn’t even entering the drain pipe of the washer
    in reply to: Bosch SGS45C02GB problem #398882
    rob yarrr
    tipped it on its front and removed all the pipes / drain pump and everything’s clear with no obstructions,pump impeller seems abit hesitant to turn, put it all back together and still no change, still won’t drain with the check water light coming on, what do ?
    in reply to: Bosch SGS45C02GB problem #398881
    rob yarrr
    how do i get to the drain pump? i’ve done as the manual says and there’s nothing i can see wrong with the sump
