rosie-lee
  • in reply to: Bosch Fridge/Freezer, Fridge 2 warm #203740
    rosie-lee
    Re: Bosch Fridge/Freezer, Fridge 2 warm
    The repair was free as i fixed it myself but wouldn’t recommend it unless you are competent with circuit boards / electrics. All the info was found on this site so if you search for Bosch info you will find the cure. Good luck. 😉
    in reply to: Bosch Fridge/Freezer, Fridge 2 warm #203738
    rosie-lee
    Problem now fixed 🙂 Faulty thermistor bypassed and now all OK. Thanks for your help everyone. 🙂
    in reply to: Bosch Fridge/Freezer, Fridge 2 warm #203737
    rosie-lee
    I have’nt given in yet, had the thing to pieces this evening, after listening to your advice suspect it may be the pcb as i tested the resistance of the thermistors and results were approx 11K for fridge at approx 15 C and approx 17K for freezer at -1C or thereabouts ( god knows where they are located though ? ), I really dont know alot more than this though so by proccess of elimination i suspect the pcb. Somebody please tell me if that sounds about right and if so where can a buy a pcb from ? Any ideas on how much they are ? Thanks again.
    in reply to: Bosch Fridge/Freezer, Fridge 2 warm #203736
    rosie-lee
    Thanks 4 ur advice helo_75, I’ll not give up just yet, i’ll try a local refridgeration engineer for an estimate and not give up on Bosch yet, maybe i’m expecting it to last forever but 5 years only seems like 2 or 3 !!! 🙂
    in reply to: Bosch Fridge/Freezer, Fridge 2 warm #203734
    rosie-lee
    Oh Dear, sounds expensive !! Might be aswell to buy a new model though very dissapointed with Bosch if this is the case. Don’t think i’ll buy another Bosch. But please reply if you think you may be able to help. Thanks.
    in reply to: Bosch Fridge/Freezer, Fridge 2 warm #203732
    rosie-lee
    Hi, dissapointing new this morning after last nights defrost, freezer and fridge cooled ok initially and then this morning freezer OK but fridge not cooling again. so i switched it off and then on again and compressor starts ok but it seems as though a thermostat on the fridge is not working ! Can you tell me where this is and where to get a replacement. Many thanks.
    in reply to: Bosch Fridge/Freezer, Fridge 2 warm #203730
    rosie-lee
    Thank you very much for your reply, i have defrosted the fridge/freezer this evening and will check the fridge temperature in the morning. I will let you know how i’ve got on. Also thanks for the link which makes interesting reading but i’m not sure mine is a ” frost free ” model, it looks like conventional fridge/freezer with cooling elements in the freezer and the usual compressor and cooling pipework on the back, thanks, i appreciate your help .
