royston h
  • in reply to: Indesit DV620whuk pcb inisialize #365008
    royston h
    Re: Indesit DV620whuk pcb inisialize
    Thank you very much 🙂
    in reply to: Indesit DV620whuk pcb inisialize #365006
    royston h
    Sent the other board back explained the problem and the board that i needed and i have been sent through a C00143211 VERSION S1 is this one ok before i unpack it all ?
    thanks
    in reply to: Indesit DV620whuk pcb inisialize #365004
    royston h
    50207 3058 thanks sorry must learn to read properly
    in reply to: Indesit DV620whuk pcb inisialize #365002
    royston h
    Just put the old board back in and it worked straight away but the water temp did not rise, the numbers on the new board are 21500933903 ID:1013721 is this correct?
    in reply to: Indesit DV620whuk pcb inisialize #365001
    royston h
    Thanks for the reply i did check the heater element and it was fine i will try what you suggested not sure on the serial number as its fitted in machine at the minute i will check that next and fit the old board again, i will report back and thanks again
    in reply to: Indesit DV620whuk pcb inisialize #364999
    royston h
    The water would not get hot everything else worked fine the new board is a C00143206 and it has a buzzer the old one which i still have has 21010324502 S1 ID:4014622 on it and had no buzzer.
